koenigsegg cc8s
Uygar
seri üretilen dünyanın en hızlı araçları olarak biliniyor, en azından ben öyle biliyorum :tey:
Performance
Acceleration: 0-100 km/h (0–62 mph) under 3.5 seconds
Top speed: 390 km/h (240 mph)
Standing quartermile: 10 seconds, end speed 217 km/h (135 mph)
Braking distance: 32 m (100–0 km/h)
Engine
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 210 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 10W60 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Supercharging with 1.0 bar boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 655 bhp at 6.800 rpm.
Maximum torque: 750 Nm (550 ftlb) at 5.000 rpm.
Maximum rpm: 7.300 rpm.
abi o sadece motorun agırlıgı, ilk önce bende öle sanmıstım ama sonra baktım motor bilgilerinin altına yazmıslar_ilginc bi istatistik olmus hakkatten  8:)_
