Lamborghini Reventon
Guest infsphinx
Lamborghini Reventon Technical data
Frame
High strength tubular steel structure with carbon fibre components.
Bodywork
In carbon fibre, except roof and door external panels (steel)
Steering
Type Mechanical (rack and pinion) power-assisted
Right-hand turning circle 12.55 m (41.17 ft)
Wheels and tyres
Front 245/35 ZR 18
Rear 335/30 ZR 18
Engine
Type 12 cylinders at 60°
Bore and stroke 88 mm x 89 mm (3.46 in x 3.50 in)
Displacement 6496 cc (396.41 in3)
Compression ratio (11  0.2):1
Maximum power 650 HP (478 kW) at 8000 rpm (guaranteed through the engine selection)
Maximum torque 660 Nm (487 lb-ft) at 6000 rpm Engine position in vehicle Longitudinal central-rear
Cylinder heads and engine block Aluminium
Intake system Variable geometry with 3 operating modes
Timing
4 valves per cylinder, 4 overhead camshafts
Timing gear transmission 2 chains
Continuous timing variator (int. and ex.) Electronically controlled
Ignition system
Static type ignition system with individual coils (one for each spark plug).
Firing sequence 1-7-4-10-2-8-6-12-3-9-5-11
Fuel system/injection
Lamborghini LIE electronic engine control unit, multipoint, sequential timed, DRIVE BY WIRE
Lubrication system
Type Dry sump
Recovery pumps 2 gear pumps
Delivery pump (high pressure) 1 gear pump
Cooling system
Type Liquid cooled, with pressurized circuit
Transmission
Type of transmission Permanent all-wheel drive with Viscous Traction system
Gearbox 6-speed mechanical gearbox
Clutch Dry single disc
Clutch disc diameter 272 mm (10.7 in)
Transmission ratios
Gearbox:
Ist 1:3.091
IInd 1:2.105
IIIrd 1:1.565
IVth 1:1.241
Vth 1:1.065
VIth 1:0.939
Reverse 1:2.692
Brakes
4 self-ventilated rotors with pedal control, hydraulic transmission with dual independent circuits, one for each axle with vacuum servo.
ABS antilock device + DRP function.
Steel brake lines
Front rotor Ø 380 x 34 mm (14.96 in x 1.34 in)
Front calliper cylinders N. 8 (32-28 mm/32-28 mm)
(1.26 in-1.10 in/1.26 in-1.10 in)
Rear rotor Ø 355 x 32 mm (13.98 in x 1.26 in)
Rear calliper cylinders N. 4 (40-44 mm)
(1.57 in-1.73 in)
Ceramic rotors system (Optional)
Front rotor Ø 380 x 38 mm (Ø 14.96 in x 1.5 in)
Front calliper cylinders N. 6 (32-36-38 mm) (1.26 in-1.42 in-1.5in)
Rear rotor Ø 380 x 38 mm (Ø 14.96 in x 1.5 in)
Rear calliper cylinders N. 6 (32-36-38 mm) (1.26 in-1.42 in-1.5in)
Handbrake Mechanical, acting on rear wheels
Suspension
4-wheel independent articulated quadrilateral system. Hydraulic shock absorbers and coaxial coil springs. Suspension with dual front and rear struts, antiroll, antidive and antisquat bar.
Performance data
Top speed 340 km/h (211.3 mph)
Acceleration 0-100 km/h (0-62 mph) 3.4 s (before: 3.8 s)
Dimensions
Wheelbase 2665 mm (104.92 in)
Total length 4700 mm (185.04 in)
Total width 2058 mm (81.02 in)
Total height 1135 mm (44.69 in)
Dry weight (no fuel and no liquids) 1665 kg (3670.7 lb)
Front trackwidth 1635 mm (64.37 in)
Rear trackwidth 1695 mm (66.73 in)
Front overhang 1080 mm (42.52 in)
Rear overhang 955 mm (37.60 in)
Maximum overall width with external rear-view mirrors 2215 mm (87.20 in)
Liquid capacities (litres)
Engine oil 12 litres (3.17 gal)
Gearbox oil 3.5 litres (0.92 gal)
Front differential oil 1 litre (0.26 gal)
Rear differential oil 2.5 litres (0.66 gal)
Cooling circuit 15 litres (3.96 gal)
Consumption (according to DIR 1999/100/CE)
Urban 32,3 l/100km
Extra-urban 15,0 l/100 km
Combined 21,3 l/100 km
CO2 emissions 495 g/km
ALINTI : DONANIMHABER
  • Yanıt 43
  • Oluşturuldu
  • Son yanıt
  • MuRDoC_111
    11
  • Uygar
    7
  • Mücahit
    5
Popüler Günler
2007 Lamborghini Reventon
Specifications
Engine
Type: V12
Displacement cu in (cc): 396 (6496)
Power bhp (kW) at RPM: 650(478) / 8000
Torque lb-ft (Nm) at RPM: 487(660) / 6000
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 245/35 ZR18 - 335/30 ZR18
Driveline: All Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 185 × 81 × 44.7
Weight lb (kg): 3671 (1665)
Performance
Acceleration 0-60 mph s: 3.3
Top Speed mph (km/h): 211 (340)
Fuel Economy EPA city/highway mpg (l/100 km): n.a. (21.3)
Base Price: 2007 Lamborghini Reventon - 1,000,000 € + taxes :o;D
[eklenti sistemin çökmesi sonucu silindi]
Guest infsphinx
  14.09.2007 at 06:31, NeBiAnd :
Arap bilmen ne prensi alacağı için bunları Önder,benzin nema problema.. ;)
abi benzin nema problema olsun artık dimi... aracın fiyatına bak 1.000.000 euro + vergiler...
bu parayı verip o ferrari gibi lpg taktırmaz artık bunu alan...
lakin ferrari 200.000 $ bu meret 1.000.000 euro yani... arada ciddi de fark var...
içmenin de ötesi bizim açımızdan eleman 100 km gidio o aletle bizim yavrularla 400 km gidioz biz ...
alana valla helal olsun manyak bi araba... benzin feda olsun öle yavruya...
kontratları var abi binek araclar için Pirelli ile yoksa Adrenalin den şaşmaz emin olun :P bende bi aralar p nero zero düsünüyodum ama herhangi bi lastik gibi desenleri, hamur dısında bi fark yaratmıyo :(
Pirelli Rosso lar on numara lastik aslında ama uzun yol lastiği,şöyle ki performansını ancak ısınınca verebiliyormuş,ama ısınınca da deli gibi yol tutuyormuş...
  14.09.2007 at 12:41, volkan :
Tamam işte tırt :D
abi temin bi para cekmeye gidip geldim lastikler sıcacıktı indigimde, daha önce çöl sıcaklarında serinlemek için sarılıyodum lastiklere :D
