Bir zamanlar Mazda
  • Mazda Cosmo Sport, of 1965, version for Japan prototype
  • 2-door coupe body type
  • RWD (rear- wheel drive), manual 4-speed gearbox
  • petrol (gasoline) engine with displacement: 982 cm3 / cui, advertised power: 81.5 kW / 109 hp / 111 PS ( JIS ), torque: 130.5 Nm / 96 lb-ft
  • characteristic dimensions: outside length: 4160 mm / 163.8 in, wheelbase: 2200 mm / 86.6 in
  • reference weights: base curb weight: 915 kg / 2017 lbs
  • how fast is this car ? top speed: 170 km/h (106 mph) (declared by factory);
  • accelerations: 0- 60 mph 9.1 s; 0- 100 km/h 9.7 s (simulation ©automobile-catalog.com); 1/4 mile drag time (402 m) 17.2 s (simulation ©automobile-catalog.com)
  • fuel consumption and mileage: average estimated by a-c: 14.9 l/100km / 18.9 mpg (imp.) / 15.7 mpg (U.S.) / 6.7 km/l
  • Mazda Capella Rotary Coupe Super Deluxe, manufactured in 1970, version for Japan Australia
  • petrol (gasoline) engine with displacement: 1146 cm3 / cui, advertised power: 95.5 kW / 128 hp / 130 PS ( JIS ), torque: 157 Nm / 116 lb-ft
  • characteristic dimensions: outside length: 4150 mm / 163.4 in, wheelbase: 2470 mm / 97.2 in
  • reference weights: base curb weight: 965 kg / 2127 lbs
  • how fast is this car ? top speed: 190 km/h (118 mph) (declared by factory);
  • accelerations: 0- 60 mph 8 s; 0- 100 km/h 8.9 s (simulation ©automobile-catalog.com); 1/4 mile drag time (402 m) 15.7 s (declared by factory)
  • fuel consumption and mileage: average estimated by a-c: 17.6 l/100km / 16.1 mpg (imp.) / 13.4 mpg (U.S.) / 5.7 km/l
  • Mazda Savanna GSII Coupe, manufactured in 1971, version for Japan
  • petrol (gasoline) engine with displacement: 982 cm3 / cui, advertised power: 81 kW / 109 hp / 110 PS ( JIS ), torque: 135 Nm / 100 lb-ft
  • characteristic dimensions: outside length: 4065 mm / 160 in, wheelbase: 2310 mm / 90.9 in
  • reference weights: base curb weight: 880 kg / 1940 lbs
  • how fast is this car ? top speed: 180 km/h (112 mph) (declared by factory);
  • accelerations: 0- 60 mph 8.7 s; 0- 100 km/h 9.3 s (simulation ©automobile-catalog.com); 1/4 mile drag time (402 m) 15.9 s (declared by factory)
  • fuel consumption and mileage: average estimated by a-c: 15.3 l/100km / 18.5 mpg (imp.) / 15.4 mpg (U.S.) / 6.5 km/l
Mete bey @Arabalar
yan aynaların konumlandırma yerleri harika ( burada dikkat ltf. özellikle yan ayna tabirini kullandım)  ^-^
Capella modeli,  sizin bir ara çekip yüklediğiniz Ankara mogan gölü fotonuzla aynı yerde çekilmiş gibi
Savanna modeli ise isminin hakkını veren bir mekanda fotosunu çektirmiş...
4 saat önce, Arman-1999 :
Mete bey @Arabalar
O kadar uzaktan  " dikiz" mi olur @Arman-1999 Kamil bey :)
